Salta al contenuto principale
Sony Vaio Fit SVF13N1ASNS Display Replacement
Cosa ti serve
  1. Sony Vaio Fit SVF13N1ASNS Display Replacement, Battery: passo 1, immagine 1 di 2 Sony Vaio Fit SVF13N1ASNS Display Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF13N1ASNS Display Replacement: passo 2, immagine 1 di 2 Sony Vaio Fit SVF13N1ASNS Display Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF13N1ASNS Display Replacement: passo 3, immagine 1 di 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: passo 3, immagine 2 di 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: passo 3, immagine 3 di 3
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF13N1ASNS Display Replacement: passo 4, immagine 1 di 1
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF13N1ASNS Display Replacement, Display: passo 5, immagine 1 di 1
    • Open the laptop and rotate the screen to the back side.
    • Remove the eight 2.85mm Phillips #00 screws from the back of the screen.
  6. Sony Vaio Fit SVF13N1ASNS Display Replacement: passo 6, immagine 1 di 2 Sony Vaio Fit SVF13N1ASNS Display Replacement: passo 6, immagine 2 di 2
    • Rotate the screen back and close the laptop.
    • Use a plastic opening tool to carefully pry up the back plastic case.
    • Remove the back plastic case by sliding it down and pulling upwards.
  7. Sony Vaio Fit SVF13N1ASNS Display Replacement: passo 7, immagine 1 di 2 Sony Vaio Fit SVF13N1ASNS Display Replacement: passo 7, immagine 2 di 2
    • Remove the thirteen 2.85mm Phillips #00 screws from the screen.
  8. Sony Vaio Fit SVF13N1ASNS Display Replacement: passo 8, immagine 1 di 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: passo 8, immagine 2 di 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: passo 8, immagine 3 di 3
    • Use a spudger to lift up the black latch on the ZIF connector.
    • Pull the display ribbon cable out of the ZIF connector.
  9. Sony Vaio Fit SVF13N1ASNS Display Replacement: passo 9, immagine 1 di 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: passo 9, immagine 2 di 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: passo 9, immagine 3 di 3
    • Remove the display cable peeling up the tape.
    • The display cable locking mechanism is attached to the tape.
  10. Sony Vaio Fit SVF13N1ASNS Display Replacement: passo 10, immagine 1 di 1
    • Remove the display.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S2-G4, Nance Spring 2018 Membro di USF Tampa, Team S2-G4, Nance Spring 2018
USFT-NANCE-S18S2G4
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,489
