Introduzione
This is an easy to follow, step by step guide to help aid in the replacement of a fan for the Sony Vaio Fit SVF14A190X. The fan helps keep your device at cool operating temperatures to prevent overheating.
Strumenti
Parti
Nessuna parte specificata.
Use the Phillips head screw driver to remove the eleven 6 mm screws.
Use the Phillips head screw driver to remove the one 4 mm screw securing the CD drive.
Use the Phillips head screw driver to remove the two 5 mm screws on the fan.
Loosen the four screws with the Phillips head screw driver on the copper cooling component. These screws will not come all of the way out.
