Salta al contenuto principale
Sony Vaio Fit SVF14A190X Battery Replacement
Cosa ti serve
  1. Sony Vaio Fit SVF14A190X  Battery Replacement, Battery Replacement: passo 1, immagine 1 di 1
    • Make sure the battery is drained or the computer is turned off.
    • Use the Phillips head screw driver to remove the eleven 6 mm screws.
    • Use the Phillips head screw driver to remove the one 4 mm screw securing the CD drive.
  2. Sony Vaio Fit SVF14A190X  Battery Replacement: passo 2, immagine 1 di 3 Sony Vaio Fit SVF14A190X  Battery Replacement: passo 2, immagine 2 di 3 Sony Vaio Fit SVF14A190X  Battery Replacement: passo 2, immagine 3 di 3
    • Insert the plastic opening tool into the slit of the CD drive.
    • Then pull it outwards.
    • Grab the CD drive with your hand.
    • Take the CD drive all the way out.
  3. Sony Vaio Fit SVF14A190X  Battery Replacement: passo 3, immagine 1 di 3 Sony Vaio Fit SVF14A190X  Battery Replacement: passo 3, immagine 2 di 3 Sony Vaio Fit SVF14A190X  Battery Replacement: passo 3, immagine 3 di 3
    • Insert the plastic opening tool into the slit between the back cover and the rest of the computer.
    • Move the plastic opening tool around all sides of the device.
    • Peel off the back cover.
  4. Sony Vaio Fit SVF14A190X  Battery Replacement: passo 4, immagine 1 di 2 Sony Vaio Fit SVF14A190X  Battery Replacement: passo 4, immagine 2 di 2
    • Use the Phillips head screw driver to remove the four 7 mm screws.
    • Lift the battery out with your hand.
Conclusione
Randal Crosby
Membro da: 02/13/18
187 Reputazione
1 Guida realizzata
USF Tampa, Team S11-G3, Cheng Spring 2018 Membro di USF Tampa, Team S11-G3, Cheng Spring 2018
USFT-CHENG-S18S11G3
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,867
