Salta al contenuto principale
Sony Vaio Fit 13A Wireless Card Replacement
Cosa ti serve
  1. Sony Vaio Fit 13A Wireless Card Replacement, Back Cover: passo 1, immagine 1 di 2 Sony Vaio Fit 13A Wireless Card Replacement, Back Cover: passo 1, immagine 2 di 2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Wireless Card Replacement: passo 2, immagine 1 di 2 Sony Vaio Fit 13A Wireless Card Replacement: passo 2, immagine 2 di 2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Wireless Card Replacement: passo 3, immagine 1 di 1
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Wireless Card Replacement, Wireless Card: passo 4, immagine 1 di 3 Sony Vaio Fit 13A Wireless Card Replacement, Wireless Card: passo 4, immagine 2 di 3 Sony Vaio Fit 13A Wireless Card Replacement, Wireless Card: passo 4, immagine 3 di 3
    • Use a pair of tweezers to gently disconnect the two antenna cables.
  5. Sony Vaio Fit 13A Wireless Card Replacement: passo 5, immagine 1 di 2 Sony Vaio Fit 13A Wireless Card Replacement: passo 5, immagine 2 di 2
    • Locate and remove the single 1mm Phillips #0 screw that is securing the wireless card to the motherboard.
  6. Sony Vaio Fit 13A Wireless Card Replacement: passo 6, immagine 1 di 2 Sony Vaio Fit 13A Wireless Card Replacement: passo 6, immagine 2 di 2
    • Gently grasp wireless card with two fingers and pull away from motherboard to the left.
    • Do not pull the wireless card up when removing it. This could snap the connections.
Conclusione
Alex Prange
Membro da: 01/08/15
527 Reputazione
3 Guide realizzate
Cal Poly, Team 21-19, Maness Winter 2015 Membro di Cal Poly, Team 21-19, Maness Winter 2015
CPSU-MANESS-W15S21G19
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,814
