Salta al contenuto principale
Sony Vaio Fit 13A SVF13NA1EL Screen Connector
Cosa ti serve
  1. Sony Vaio Fit 13A SVF13NA1EL Screen Connector, Sony Vaio Fit 13A SVF13NA1EL Screen Connector: passo 1, immagine 1 di 1
    • Flip over the screen
    • Remove all 8 screws as shown circled in the image using a Phillips #0
  2. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: passo 2, immagine 1 di 3 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: passo 2, immagine 2 di 3 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: passo 2, immagine 3 di 3
    • Flip the screen back over.
    • Use a plastic spudger to remove the top section of the cover.
  3. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: passo 3, immagine 1 di 1
    • Unplug the screen connecter from the back of the screen.
  4. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: passo 4, immagine 1 di 1
    • Disconnect the ribbon wire from the LCD connector by gently pulling it.
  5. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: passo 5, immagine 1 di 2 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: passo 5, immagine 2 di 2
    • Gently raise the metal framework of the laptop to reveal the remaining portion of the screen connector.
    • Follow the ribbon wiring to where it connects to the screen.
    • Carefully pull the wiring to disconnect and click it back in place to reconnect.
Conclusione
Altre 4 persone hanno completato questa guida.
5 Commenti
Where to buy or to repair screen connector for Vaio Fit SVF13N13
Adham Ahmed - Replica
Where to replace the keyboard of Vaio SVF13N2
Arturo Dameno - Replica
Where i buy flexi
msobirin48 - Replica
The procedure is nicely explained
Is there an option to replace the LCD flet cable ... ?
It is complicated but we found a defect on the flet cable.
servis računara - Replica
I found some spareparts over the sony website. With all data from you laptop you can find them here https://uk.eetgroup.com/Guide/m/Sony-VAI...
Lukas Lutz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 4,160
