Salta al contenuto principale
Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement
Cosa ti serve
  1. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Back Cover: passo 1, immagine 1 di 2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Back Cover: passo 1, immagine 2 di 2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: passo 2, immagine 1 di 2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: passo 2, immagine 2 di 2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: passo 3, immagine 1 di 1
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Fan: passo 4, immagine 1 di 2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Fan: passo 4, immagine 2 di 2
    • Remove the three 1mm Phillips #0 screws surrounding the fan.
    • Loosen the three 1mm Phillips #0 screws. These screws will stay captive to the heatsink.
  5. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: passo 5, immagine 1 di 3 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: passo 5, immagine 2 di 3 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: passo 5, immagine 3 di 3
    • Use tweezers to carefully unplug the fan connector.
  6. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Remove the Fan: passo 6, immagine 1 di 2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Remove the Fan: passo 6, immagine 2 di 2
    • Use the Plastic Opening Tool to gently remove the heat sink and fan assembly from the computer.
    • Important: Follow the How to Apply Thermal Paste guide to replace the thermal paste before reassembling your device.
Conclusione
Altre 4 persone hanno completato questa guida.
Marii
Membro da: 01/08/15
658 Reputazione
3 Guide realizzate
Cal Poly, Team 21-19, Maness Winter 2015 Membro di Cal Poly, Team 21-19, Maness Winter 2015
CPSU-MANESS-W15S21G19
4 Membri
12 Guide realizzate
Un commento
Could you also maybe do a tutorial on Sony Vaio Fit 13? http://www.laptoppartstore.com/replace--... Any luck figuring out how the fan may be detached and re-attached to the heatsink? Also, I notice a very specific type of taping... where can one procure those?
Abhishek D - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 4,525
