Salta al contenuto principale
Sony VAIO VPCF 132FX Media Board Replacement
Cosa ti serve
  1. Sony VAIO VPCF 132FX Media Board Replacement, Battery: passo 1, immagine 1 di 1
    • Remove all wires then flip the laptop
  2. Sony VAIO VPCF 132FX Media Board Replacement: passo 2, immagine 1 di 2 Sony VAIO VPCF 132FX Media Board Replacement: passo 2, immagine 2 di 2
    • Remove the battery
  3. Sony VAIO VPCF 132FX Media Board Replacement, Media Board: passo 3, immagine 1 di 1
    • Remove the screws and flip it back.
  4. Sony VAIO VPCF 132FX Media Board Replacement: passo 4, immagine 1 di 3 Sony VAIO VPCF 132FX Media Board Replacement: passo 4, immagine 2 di 3 Sony VAIO VPCF 132FX Media Board Replacement: passo 4, immagine 3 di 3
    • Lift the screen and slide your nail or any flat plastic to the side of the cover to unclip it.
    • Slide from the sides towards the center.
  5. Sony VAIO VPCF 132FX Media Board Replacement: passo 5, immagine 1 di 1
    • Gently remove the wire of the Power Button.
  6. Sony VAIO VPCF 132FX Media Board Replacement: passo 6, immagine 1 di 3 Sony VAIO VPCF 132FX Media Board Replacement: passo 6, immagine 2 di 3 Sony VAIO VPCF 132FX Media Board Replacement: passo 6, immagine 3 di 3
    • Unlock the Lock.
    • Unscrew the 3 Flat screws and remove the Media Board.
    • You may skip this step if replacing the Power Button.
Conclusione
Marjorie
Membro da: 12/23/13
2.273 Reputazione
11 Guide realizzate
Un commento
What are the functions of the media board? My vaio vgn-fw170j won't power up (no LEDS on the power switch, or anywhere else, no fan, nothing). Verified that MoBo has 19.5 VDC on the board. Replaced MoBo and CPU, still no response. Since power button plugs into Media Board, figured it might be failed - any idea if this could be the cause?
course2kid - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,401
