Salta al contenuto principale
Sony VAIO VPC-EB33FM RAM Replacement
Cosa ti serve
  1. Sony VAIO VPC-EB33FM RAM Replacement, Battery: passo 1, immagine 1 di 2 Sony VAIO VPC-EB33FM RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Power down the laptop by pressing the power button.
    • Turn the laptop onto its backside.
  2. Sony VAIO VPC-EB33FM RAM Replacement: passo 2, immagine 1 di 1
    • To release the battery, hold both the release button and the unlock button at the same time.
  3. Sony VAIO VPC-EB33FM RAM Replacement: passo 3, immagine 1 di 2 Sony VAIO VPC-EB33FM RAM Replacement: passo 3, immagine 2 di 2
    • Remove the battery out from the notch while continuing to hold the release button.
  4. Sony VAIO VPC-EB33FM RAM Replacement, RAM: passo 4, immagine 1 di 3 Sony VAIO VPC-EB33FM RAM Replacement, RAM: passo 4, immagine 2 di 3 Sony VAIO VPC-EB33FM RAM Replacement, RAM: passo 4, immagine 3 di 3
    • Remove the one screw with a Phillips #00 screwdriver.
    • The screw cannot be removed from the RAM casing cover.
  5. Sony VAIO VPC-EB33FM RAM Replacement: passo 5, immagine 1 di 2 Sony VAIO VPC-EB33FM RAM Replacement: passo 5, immagine 2 di 2
    • Pull the two retaining arms away from the center of the RAM chip.
    • The RAM will make a "pop" sound and the RAM stick will rise for ease of handling.
  6. Sony VAIO VPC-EB33FM RAM Replacement: passo 6, immagine 1 di 3 Sony VAIO VPC-EB33FM RAM Replacement: passo 6, immagine 2 di 3 Sony VAIO VPC-EB33FM RAM Replacement: passo 6, immagine 3 di 3
    • Pull the RAM stick out of its socket.
    • To remove the second stick of RAM, repeat steps six and seven.
    • When installing RAM, make sure sticks are firmly in place or the computer will not register them.
Conclusione
Bret Omsberg
Membro da: 01/14/13
16 Reputazione
1 Guida realizzata
Cal Poly, Team 18-39, Regan Winter 2013 Membro di Cal Poly, Team 18-39, Regan Winter 2013
CPSU-REGAN-W13S18G39
5 Membri
15 Guide realizzate
Un commento
when i press the power button in VAio still black screen with little tick sound,
and one day i just turn it on and leave it for 17 hours and sadnlley it worked but when i tried to restart it it still not working with tick tick tick tick sound !!! any advise !!!?
dorii135 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 4,306
