Salta al contenuto principale
Sony VAIO VPC-EB33FM Hard Drive Replacement
Cosa ti serve
  1. Sony VAIO VPC-EB33FM Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 Sony VAIO VPC-EB33FM Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Power down the laptop by pressing the power button.
    • Turn the laptop onto its backside.
  2. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 2, immagine 1 di 1
    • To release the battery, hold both the release button and the unlock button at the same time.
  3. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 3, immagine 1 di 2 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 3, immagine 2 di 2
    • Remove the battery out from the notch while continuing to hold the release button.
  4. Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 3 Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: passo 4, immagine 2 di 3 Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: passo 4, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the two 7.8 mm cover screws on the bottom corners of the panel.
  5. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 5, immagine 1 di 3 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 5, immagine 2 di 3 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 5, immagine 3 di 3
    • Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
    • You may need to use your other hand to safely remove the panel.
    • You can also use a spudger for this step.
  6. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 6, immagine 1 di 1
    • Remove the two remaining 7.8 mm screws using the Phillips #00 screwdriver.
  7. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 7, immagine 1 di 1
    • Grab the tab between your thumb and index finger.
    • Hold the hard drive securely in a horizontal position using your other hand.
    • Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
    • To prevent damage of the connection on the hard disk drive or the laptop, perform this task slowly and with care.
  8. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 8, immagine 1 di 2 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 8, immagine 2 di 2
    • While still holding the plastic tab, lift the right side of the hard drive out at a 45ยบ angle.
    • Pull the hard drive out.
  9. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 9, immagine 1 di 2 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 9, immagine 2 di 2
    • If you need to remove the bracket from the hard drive, follow the next few steps:
    • Remove the two 3.7 mm screws from either side of the bracket with a Phillips #00 screwdriver.
    • Lift the bracket off the hard drive.
Conclusione
Altre 8 persone hanno completato questa guida.
Christian
Membro da: 01/14/13
177 Reputazione
1 Guida realizzata
Cal Poly, Team 18-39, Regan Winter 2013 Membro di Cal Poly, Team 18-39, Regan Winter 2013
CPSU-REGAN-W13S18G39
5 Membri
15 Guide realizzate
Un commento
This is very good step by step instructions guide. Loved it and was able to remove my laptop hd very easily. I created this account only to say thanks to writer. Amazing job !! Thaks ton.
Dinesh - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 18,422
