Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide will inform readers on how to safely remove the fan of the Sony VAIO VPC-EB33FM laptop for replacement.
  1. If the laptop isn't turned off, then do so by holding down the power button. Turn the laptop onto its backside.
    • If the laptop isn't turned off, then do so by holding down the power button.
    • Turn the laptop onto its backside.
  2. Locate the battery below the screen attachment.
    • Locate the battery below the screen attachment.
    • The battery is shaped as a long rectangle with rounded edges.
  3. Press into the release button while holding the unlock button in position.
    • Press into the release button while holding the unlock button in position.
  4. Lift the battery out at the notch while holding the release button. Lift the battery out at the notch while holding the release button.
    • Lift the battery out at the notch while holding the release button.
  5. Remove all charge from the laptop by holding down the power button for at least 5 seconds.
    • Remove all charge from the laptop by holding down the power button for at least 5 seconds.
  6. Turn laptop onto its backside and locate the hard drive cover panel. Turn laptop onto its backside and locate the hard drive cover panel.
    • Turn laptop onto its backside and locate the hard drive cover panel.
  7. Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel. Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel. Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel.
    • Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel.
  8. Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off. You may need to use your other hand to safely remove the panel. You can also use a spudger for this step
    • Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
    • You may need to use your other hand to safely remove the panel.
    • You can also use a spudger for this step
  9. The hard drive should now be exposed.
    • The hard drive should now be exposed.
    • Remove the two remaining 7.75-mm screws using the Phillips #00 screwdriver.
  10. Grab the tab between your thumb and index finger.
    • Grab the tab between your thumb and index finger.
    • Hold the hard drive securely in a horizontal position using your other hand.
    • Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
    • To prevent damage of the connection on the hard disk drive or the laptop, perform this task slowly and with care.
  11. While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle. Pull the hard drive out.
    • While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle.
    • Pull the hard drive out.
  12. If you need to remove the bracket from the hard drive, follow the next few steps: Remove the two 3.67-mm screws from either side of the bracket with a Phillips #00 screwdriver.
    • If you need to remove the bracket from the hard drive, follow the next few steps:
    • Remove the two 3.67-mm screws from either side of the bracket with a Phillips #00 screwdriver.
    • Lift the bracket off the hard drive.
  13. Remove the one screw with a Phillips #00 screwdriver. The screw cannot be removed from the RAM casing cover. The screw cannot be removed from the RAM casing cover.
    • Remove the one screw with a Phillips #00 screwdriver.
    • The screw cannot be removed from the RAM casing cover.
  14. Pull the two retaining arms away from the center of the RAM chip. The RAM will make a "pop" sound and the RAM stick will rise for ease of handling.
    • Pull the two retaining arms away from the center of the RAM chip.
    • The RAM will make a "pop" sound and the RAM stick will rise for ease of handling.
  15. Pull the RAM stick out of its socket. To remove the second stick of RAM, repeat steps six and seven. When installing RAM, make sure sticks are firmly in place or the computer will not register them.
    • Pull the RAM stick out of its socket.
    • To remove the second stick of RAM, repeat steps six and seven.
    • When installing RAM, make sure sticks are firmly in place or the computer will not register them.
  16. Remove the following 16 screws securing the back cover using a Phillips #00 screwdriver:
    • Remove the following 16 screws securing the back cover using a Phillips #00 screwdriver:
    • Two 3.8-mm screws
    • Two 8.9-mm screws
    • Twelve 7.75-mm screws
  17. Check to make sure all the screws have been removed.
    • Check to make sure all the screws have been removed.
    • Using both hands, separate the back cover by lifting from the back and working around the perimeter to release tabs.
  18. Locate the fan and the processor attachment. Locate the fan and the processor attachment.
    • Locate the fan and the processor attachment.
  19. Using a Phillips #00 screwdriver, remove the top four 3.88-mm fan screws.
    • Using a Phillips #00 screwdriver, remove the top four 3.88-mm fan screws.
  20. Remove the two 5.7-mm screws located at the base of the fan, using a Phillips #00 screwdriver.
    • Remove the two 5.7-mm screws located at the base of the fan, using a Phillips #00 screwdriver.
  21. Pull back the tape located on the far side of the fan.
    • Pull back the tape located on the far side of the fan.
  22. Remove the wired connection between the fan and the copper wire using metal tweezers.
    • Remove the wired connection between the fan and the copper wire using metal tweezers.
    • Do not to pull on the wires directly or it will damage the connection between the fan and the laptop.
  23. Remove the four 5.65-mm screws on the processor corners using a Phillips #00 screwdriver.
    • Remove the four 5.65-mm screws on the processor corners using a Phillips #00 screwdriver.
  24. You are now ready to remove fan and processor connection Position thumbs and index fingers close to processor and lift up on the copper wire, while applying slight downward pressure on the motherboard with remaining fingers.
    • You are now ready to remove fan and processor connection
    • Position thumbs and index fingers close to processor and lift up on the copper wire, while applying slight downward pressure on the motherboard with remaining fingers.
    • If there is thermal paste between the processor and the fan attachment, increased force will be required to detach the fan.
Conclusione
Altre 16 persone hanno completato questa guida.
Kevin
Membro da: 11/01/2013
499 Reputazione
3 Guide realizzate
Cal Poly, Team 18-39, Regan Winter 2013 Membro di Cal Poly, Team 18-39, Regan Winter 2013
CPSU-REGAN-W13S18G39
5 Membri
6 Guide realizzate
I don't know who you are, but you are a god to me!! Laptop is fixed and humming along like it is supposed to!!
Great and easy directions, thank you from the bottom of my heart....and the bottom of my husbands wallet!
creaper126 - Replica
Hi, I would like to upgrade my core i3 370M processor. How can I know the compatible core i5 or i7 to replace?
Material
Tudo praObra - Replica
Thanks!! This is very helpful.
Charlie Tai - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 36
Tutti i Tempi: 19,399
