Salta al contenuto principale
Sony VAIO VGN-FW 590 Keyboard Replacement
Cosa ti serve
  1. Sony VAIO VGN-FW 590 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Sony VAIO VGN-FW 590 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the computer off, close the LCD screen, and insure the computer is unplugged from any outlet.
    • Turn the computer over so that the bottom of the computer is facing up and the "screen swivels" (DC in port and On button) are facing away from you.
    • Locate the battery pack between the two "screen swivels" at the top of the computer back.
  2. Sony VAIO VGN-FW 590 Keyboard Replacement: passo 2, immagine 1 di 2 Sony VAIO VGN-FW 590 Keyboard Replacement: passo 2, immagine 2 di 2
    • Locate two sliding release switches below the battery pack.
    • Slide the "Lock" release to the right toward the center of the computer.
    • Slide the "Release" switch to the left, toward the center of the computer. It must be held in place because it is spring loaded.
  3. Sony VAIO VGN-FW 590 Keyboard Replacement: passo 3, immagine 1 di 2 Sony VAIO VGN-FW 590 Keyboard Replacement: passo 3, immagine 2 di 2
    • While holding the "Release" switch toward the center of the computer, press on the raised portion of the battery pack away from you. The battery pack will pop up.
    • Once the battery pack has popped out of its compartment, lift it out of the computer.
  4. Sony VAIO VGN-FW 590 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 1
    • Remove the circled screws using the Phillips #0 screwdriver.
    • The outer two screws are 7.7mm
    • The center two screws are 2.5mm
    • The bottom screw is 7.6mm
  5. Sony VAIO VGN-FW 590 Keyboard Replacement: passo 5, immagine 1 di 1
    • Open the computer
  6. Sony VAIO VGN-FW 590 Keyboard Replacement: passo 6, immagine 1 di 1
    • Remove the audio panel above the keyboard.
    • Lift one corner gently with a flat tool or fingernail.
    • Pull the rest of the panel gently out by hand.
  7. Sony VAIO VGN-FW 590 Keyboard Replacement: passo 7, immagine 1 di 1
    • Lift the keyboard gently, starting with one of the top corners.
    • Pull keyboard gently from body of computer to prevent warping or breakage.
    • Caution Do not remove completely.
  8. Sony VAIO VGN-FW 590 Keyboard Replacement: passo 8, immagine 1 di 3 Sony VAIO VGN-FW 590 Keyboard Replacement: passo 8, immagine 2 di 3 Sony VAIO VGN-FW 590 Keyboard Replacement: passo 8, immagine 3 di 3
    • Locate the connector ribbon behind the keyboard.
    • Gently pull the ribbon from the locking device. It may take a few tries.
    • Caution Do not tear the ribbon.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,043
