Introduzione
This guide is for users whose VAIO VGN-FW590 keyboard no longer functions. Before starting please be aware that keyboards warps easily during the removal/replacement process. If you wish to reuse/replace your keyboard be very careful and perform each step gently.
Strumenti
Parti
Turn the computer off, close the LCD screen, and insure the computer is unplugged from any outlet.
Turn the computer over so that the bottom of the computer is facing up and the "screen swivels" (DC in port and On button) are facing away from you.
Locate the battery pack between the two "screen swivels" at the top of the computer back.
Remove the circled screws using the Phillips #0 screwdriver.
The outer two screws are 7.7mm
The center two screws are 2.5mm
The bottom screw is 7.6mm
