Salta al contenuto principale
Introduzione
This guide will show Sony Vaio owners how to repair individual keys on their keyboard.
Parti
Nessuna parte specificata.
  1. Open your computer.
    • Open your computer.
    • Make sure the computer is turned off.
  2. Find the broken key.
    • Find the broken key.
    • The S key is our example though it is not broken.
  3. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  4. Insert the plastic spudger underneath the edge of the key. Lift the key until it pops off on all four corners. There should be a white plastic base underneath the key.
    • Insert the plastic spudger underneath the edge of the key.
    • Lift the key until it pops off on all four corners. There should be a white plastic base underneath the key.
  5. Orient replacement key over the white plastic base, so it is aligned properly with the other keys.
    • Orient replacement key over the white plastic base, so it is aligned properly with the other keys.
    • Press the replacement key firmly in the center until it is completely depressed and attached to the key base.
  6. Test the key by releasing the key. It should pop up and look like the rest of the keys on the keyboard.
    • Test the key by releasing the key. It should pop up and look like the rest of the keys on the keyboard.
Conclusione
Congratulations! You have successfully replaced a key on your keyboard.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 543
