Salta al contenuto principale
Sony VAIO VGN-FW 590 Battery Replacement
Cosa ti serve
  1. Sony VAIO VGN-FW 590 Battery Replacement, Battery: passo 1, immagine 1 di 2 Sony VAIO VGN-FW 590 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the computer off, close the LCD screen, and insure the computer is unplugged from any outlet.
    • Turn the computer over so that the bottom of the computer is facing up and the "screen swivels" (DC in port and On button) are facing away from you.
    • Locate the battery pack between the two "screen swivels" at the top of the computer back.
  2. Sony VAIO VGN-FW 590 Battery Replacement: passo 2, immagine 1 di 2 Sony VAIO VGN-FW 590 Battery Replacement: passo 2, immagine 2 di 2
    • Locate two sliding release switches below the battery pack.
    • Slide the "Lock" release to the right toward the center of the computer.
    • Slide the "Release" switch to the left, toward the center of the computer. It must be held in place because it is spring loaded.
  3. Sony VAIO VGN-FW 590 Battery Replacement: passo 3, immagine 1 di 2 Sony VAIO VGN-FW 590 Battery Replacement: passo 3, immagine 2 di 2
    • While holding the "Release" switch toward the center of the computer, press on the raised portion of the battery pack away from you. The battery pack will pop up.
    • Once the battery pack has popped out of its compartment, lift it out of the computer.
Conclusione
Morton Wakeland
Membro da: 10/30/17
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 799
