Salta al contenuto principale
Sony VAIO SVE14AJ16L Wireless Network Card Replacement
Cosa ti serve
  1. Sony VAIO SVE14AJ16L Wireless Network Card Replacement, Wireless Network Card: passo 1, immagine 1 di 1
    • Remove the twelve 5 mm Phillips #0 screws from the bottom of the laptop.
  2. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: passo 2, immagine 1 di 1
    • Remove the two 5 mm Phillips #0 screws from the bottom of the laptop.
  3. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: passo 3, immagine 1 di 1
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  4. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: passo 4, immagine 1 di 1
    • Disconnect the black and white antenna wires from the wifi card.
    • Make sure to lift the plugs straight up from the sockets and not from an angle.
  5. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: passo 5, immagine 1 di 2 Sony VAIO SVE14AJ16L Wireless Network Card Replacement: passo 5, immagine 2 di 2
    • Remove the 3 mm Phillips #0 screw from the wifi card.
    • Remove the card from its socket.
Conclusione
Altre 2 persone hanno completato questa guida.
2 Commenti
Perfect hardware guide, but i make this and windows 10 recognizes the card, but does not start the Wifi, my laptop SVE14A2X1EW does not have wifi switch or Fn buttons, and I have no way to enable the wifi, some trick?
VirusBCN - Replica
Please follow this guide to enable wifi and bluetooth on this device for any modern wifi card:
gsid.in/using-old-mini-pcie-wlan-cards-in-modern-laptops/
Daniel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 30
Tutti i Tempi: 2,450
