Salta al contenuto principale
Sony VAIO SVE14AJ16L RAM Replacement
Cosa ti serve
  1. Sony VAIO SVE14AJ16L RAM Replacement, RAM: passo 1, immagine 1 di 1
    • Turn your laptop off before starting.
    • Turn the laptop upside down onto the closed lid so that the bottom is facing you.
  2. Sony VAIO SVE14AJ16L RAM Replacement: passo 2, immagine 1 di 2 Sony VAIO SVE14AJ16L RAM Replacement: passo 2, immagine 2 di 2
    • Locate and remove the lone screw on the RAM cover with a Phillips #0 head screw driver.
    • Carefully pry the RAM cover up.
    • There will be some resistance, so use strength and not speed to remove the cover.
  3. Sony VAIO SVE14AJ16L RAM Replacement: passo 3, immagine 1 di 3 Sony VAIO SVE14AJ16L RAM Replacement: passo 3, immagine 2 di 3 Sony VAIO SVE14AJ16L RAM Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    iFixit Opening Tool
    $1.99
    Compra
    • With the cover removed, peel back the black protective plastic to expose one of the two RAM sticks.
    • Make sure not to touch any part of the blue board itself, and only handle the stick from it's edges.
    • Gently, but firmly push back the two side anchors that hold in the RAM using either an iFixit Opening Tool or your fingernails.
  4. Sony VAIO SVE14AJ16L RAM Replacement: passo 4, immagine 1 di 2 Sony VAIO SVE14AJ16L RAM Replacement: passo 4, immagine 2 di 2
    • Once both anchors are released from the RAM stick, the stick will spring up at an angle
    • Finally, carefully pull the RAM stick away from the laptop at the same angle it is sitting at.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 548
