Salta al contenuto principale
Sony VAIO PCG-F360 Speaker Panel Replacement
Cosa ti serve
  1. Sony VAIO PCG-F360 Speaker Panel Replacement, Battery: passo 1, immagine 1 di 1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony VAIO PCG-F360 Speaker Panel Replacement: passo 2, immagine 1 di 1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony VAIO PCG-F360 Speaker Panel Replacement: passo 3, immagine 1 di 1
    • Use the indentations to pull the old battery out.
  4. Sony VAIO PCG-F360 Speaker Panel Replacement: passo 4, immagine 1 di 1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony VAIO PCG-F360 Speaker Panel Replacement, Speaker Panel: passo 5, immagine 1 di 3 Sony VAIO PCG-F360 Speaker Panel Replacement, Speaker Panel: passo 5, immagine 2 di 3 Sony VAIO PCG-F360 Speaker Panel Replacement, Speaker Panel: passo 5, immagine 3 di 3
    • There are two screws on the left hand side of the laptop near the IR receiver. remove them using a #00 Philips head screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony VAIO PCG-F360 Speaker Panel Replacement: passo 6, immagine 1 di 3 Sony VAIO PCG-F360 Speaker Panel Replacement: passo 6, immagine 2 di 3 Sony VAIO PCG-F360 Speaker Panel Replacement: passo 6, immagine 3 di 3
    • Push the beige tab in the direction of the ribbon. it should only move a small amount
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 181
