Salta al contenuto principale
Sony VAIO PCG-F360 Single Key Replacement
Cosa ti serve
  1. Sony VAIO PCG-F360 Single Key Replacement, Battery: passo 1, immagine 1 di 1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony VAIO PCG-F360 Single Key Replacement: passo 2, immagine 1 di 1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony VAIO PCG-F360 Single Key Replacement: passo 3, immagine 1 di 1
    • Use the indentations to pull the old battery out.
  4. Sony VAIO PCG-F360 Single Key Replacement: passo 4, immagine 1 di 1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony VAIO PCG-F360 Single Key Replacement, Single Key: passo 5, immagine 1 di 3 Sony VAIO PCG-F360 Single Key Replacement, Single Key: passo 5, immagine 2 di 3 Sony VAIO PCG-F360 Single Key Replacement, Single Key: passo 5, immagine 3 di 3
    • Use the pludger to pop off the key by prying under it.
    • You now can clean and replace the key.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 192
