Salta al contenuto principale
Sony VAIO PCG-933A Keyboard Replacement
Cosa ti serve
  1. Sony VAIO PCG-933A Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Sony VAIO PCG-933A Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A Keyboard Replacement: passo 2, immagine 1 di 3 Sony VAIO PCG-933A Keyboard Replacement: passo 2, immagine 2 di 3 Sony VAIO PCG-933A Keyboard Replacement: passo 2, immagine 3 di 3
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Sony VAIO PCG-933A Keyboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
  4. Sony VAIO PCG-933A Keyboard Replacement: passo 4, immagine 1 di 2 Sony VAIO PCG-933A Keyboard Replacement: passo 4, immagine 2 di 2
    • Remove the 4mm screw on the right rear side of the laptop next to the audio ports using a Phillips #0 screwdriver.
    • This will release the speaker grille.
  5. Sony VAIO PCG-933A Keyboard Replacement: passo 5, immagine 1 di 1
    • Flip the computer so the key board is facing up.
  6. Sony VAIO PCG-933A Keyboard Replacement: passo 6, immagine 1 di 3 Sony VAIO PCG-933A Keyboard Replacement: passo 6, immagine 2 di 3 Sony VAIO PCG-933A Keyboard Replacement: passo 6, immagine 3 di 3
    • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
    • Carefully pull out the white electrical strip. By doing this you will remove the speaker grille.
  7. Sony VAIO PCG-933A Keyboard Replacement: passo 7, immagine 1 di 3 Sony VAIO PCG-933A Keyboard Replacement: passo 7, immagine 2 di 3 Sony VAIO PCG-933A Keyboard Replacement: passo 7, immagine 3 di 3
    • Remove the 4mm screw in the center using a Phillips screwdriver.
    • Carefully and slowly pull the green strip straight up (away from the laptop) to disconnect it. Make sure not to pull too hard to avoid breaking.
    • The keyboard can now be removed.
Conclusione
Sara Lillard
Membro da: 04/11/11
165 Reputazione
8 Guide realizzate
Cal Poly, Team 12-36, Maness Spring 2011 Membro di Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,785
