Salta al contenuto principale
Sony VAIO PCG-933A Hard Drive Replacement
Cosa ti serve
  1. Sony VAIO PCG-933A Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 Sony VAIO PCG-933A Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A Hard Drive Replacement: passo 2, immagine 1 di 3 Sony VAIO PCG-933A Hard Drive Replacement: passo 2, immagine 2 di 3 Sony VAIO PCG-933A Hard Drive Replacement: passo 2, immagine 3 di 3
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Sony VAIO PCG-933A Hard Drive Replacement, Keyboard: passo 3, immagine 1 di 1
    • Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
  4. Sony VAIO PCG-933A Hard Drive Replacement: passo 4, immagine 1 di 2 Sony VAIO PCG-933A Hard Drive Replacement: passo 4, immagine 2 di 2
    • Remove the 4mm screw on the right rear side of the laptop next to the audio ports using a Phillips #0 screwdriver.
    • This will release the speaker grille.
  5. Sony VAIO PCG-933A Hard Drive Replacement: passo 5, immagine 1 di 1
    • Flip the computer so the key board is facing up.
  6. Sony VAIO PCG-933A Hard Drive Replacement: passo 6, immagine 1 di 3 Sony VAIO PCG-933A Hard Drive Replacement: passo 6, immagine 2 di 3 Sony VAIO PCG-933A Hard Drive Replacement: passo 6, immagine 3 di 3
    • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
    • Carefully pull out the white electrical strip. By doing this you will remove the speaker grille.
  7. Sony VAIO PCG-933A Hard Drive Replacement: passo 7, immagine 1 di 3 Sony VAIO PCG-933A Hard Drive Replacement: passo 7, immagine 2 di 3 Sony VAIO PCG-933A Hard Drive Replacement: passo 7, immagine 3 di 3
    • Remove the 4mm screw in the center using a Phillips screwdriver.
    • Carefully and slowly pull the green strip straight up (away from the laptop) to disconnect it. Make sure not to pull too hard to avoid breaking.
    • The keyboard can now be removed.
  8. Sony VAIO PCG-933A Hard Drive Replacement, Hard Drive: passo 8, immagine 1 di 2 Sony VAIO PCG-933A Hard Drive Replacement, Hard Drive: passo 8, immagine 2 di 2
    • Remove the two 4mm Phillips screws in the center of the computer located on each side of the copper electrical strip.
  9. Sony VAIO PCG-933A Hard Drive Replacement: passo 9, immagine 1 di 3 Sony VAIO PCG-933A Hard Drive Replacement: passo 9, immagine 2 di 3 Sony VAIO PCG-933A Hard Drive Replacement: passo 9, immagine 3 di 3
    • Remove the four 4mm Phillips screws around the hard drive cage.
    • WARNING: DVD drive is now loose as well.
    • Carefully lift the hard drive cage out.
    • Carefully disconnect the copper strip to pull out the hard drive.
  10. Sony VAIO PCG-933A Hard Drive Replacement: passo 10, immagine 1 di 3 Sony VAIO PCG-933A Hard Drive Replacement: passo 10, immagine 2 di 3 Sony VAIO PCG-933A Hard Drive Replacement: passo 10, immagine 3 di 3
    • Remove the four 4mm Phillips screws that hold the hard drive in the hard drive cage.
    • Gently remove the hard drive from the cage.
    • Gently remove the copper electrical strip from the harddrive.
Conclusione
Altre 4 persone hanno completato questa guida.
Sara Lillard
Membro da: 04/11/11
165 Reputazione
8 Guide realizzate
Cal Poly, Team 12-36, Maness Spring 2011 Membro di Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Membri
16 Guide realizzate
2 Commenti
Totally dident expect to find a guide for taking this one apart. Appreciate it!
pat - Replica
Complete Life Saver Thank you Very much for taking the time to Make an Easily Fallowed guide for this laptop. very very much Appreciated
colbailey1 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 32
Tutti i Tempi: 7,387
