Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This repair guide illustrates how to replace the Floppy Disk Drive.
  1. Turn the laptop upside down The battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
    • Turn the laptop upside down
    • The battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. As shown by the arrow, slide the plastic cover up and then pull out and downwards. You should now be able to pull the battery out. You should now be able to pull the battery out.
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. With the laptop facing you, turn the laptop upside down.
    • With the laptop facing you, turn the laptop upside down.
  5. Locate the release switch in the center of the laptop, shown here. Slide the switch, and hold in place.  The floppy disk drive is now free and should easily slide out. Slide the switch, and hold in place.  The floppy disk drive is now free and should easily slide out.
    • Locate the release switch in the center of the laptop, shown here.
    • Slide the switch, and hold in place. The floppy disk drive is now free and should easily slide out.
  6. To replace, insert the new floppy disk drive with the wording facing down.
    • To replace, insert the new floppy disk drive with the wording facing down.
Conclusione
Sara Lillard
Membro da: 11/04/2011
141 Reputazione
8 Guide realizzate
Cal Poly, Team 12-36, Maness Spring 2011 Membro di Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,678
