Salta al contenuto principale
Sony VAIO VPCEE26FX RAM Replacement
Cosa ti serve
  1. Sony VAIO VPCEE26FX RAM Replacement, Battery: passo 1, immagine 1 di 2 Sony VAIO VPCEE26FX RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX RAM Replacement: passo 2, immagine 1 di 2 Sony VAIO VPCEE26FX RAM Replacement: passo 2, immagine 2 di 2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX RAM Replacement, RAM: passo 3, immagine 1 di 1
    • Using a JIS #0 screwdriver, loosen the captive screw attached to the RAM cover.
    • This screw will not come out all the way, but will remain attached to the cover instead.
  4. Sony VAIO VPCEE26FX RAM Replacement: passo 4, immagine 1 di 1
    • Remove the cover which will reveal the two RAM sticks.
  5. Sony VAIO VPCEE26FX RAM Replacement: passo 5, immagine 1 di 3 Sony VAIO VPCEE26FX RAM Replacement: passo 5, immagine 2 di 3 Sony VAIO VPCEE26FX RAM Replacement: passo 5, immagine 3 di 3
    • Push the two tabs holding the RAM sticks in place, away from each other.
    • The first RAM stick will pop up out of place. Remove it away from its position.
  6. Sony VAIO VPCEE26FX RAM Replacement: passo 6, immagine 1 di 3 Sony VAIO VPCEE26FX RAM Replacement: passo 6, immagine 2 di 3 Sony VAIO VPCEE26FX RAM Replacement: passo 6, immagine 3 di 3
    • Push the two tabs holding the second RAM stick in, away from each other.
    • The second RAM stick will pop up out of place. Remove it away from its position.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,375
