Salta al contenuto principale
Sony VAIO VPCEE26FX Optical Drive Replacement
Cosa ti serve
  1. Sony VAIO VPCEE26FX Optical Drive Replacement, Battery: passo 1, immagine 1 di 2 Sony VAIO VPCEE26FX Optical Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Optical Drive Replacement: passo 2, immagine 1 di 2 Sony VAIO VPCEE26FX Optical Drive Replacement: passo 2, immagine 2 di 2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Optical Drive Replacement, Optical Drive: passo 3, immagine 1 di 1
    • Use a JIS #0 screwdriver to remove the 4mm screw from its place.
  4. Sony VAIO VPCEE26FX Optical Drive Replacement: passo 4, immagine 1 di 2 Sony VAIO VPCEE26FX Optical Drive Replacement: passo 4, immagine 2 di 2
    • Remove the optical drive gently away from its holder on the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 436
