Salta al contenuto principale
Sony VAIO VPCEE26FX Battery Replacement
  1. Sony VAIO VPCEE26FX Battery Replacement, Battery: passo 1, immagine 1 di 2 Sony VAIO VPCEE26FX Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Battery Replacement: passo 2, immagine 1 di 2 Sony VAIO VPCEE26FX Battery Replacement: passo 2, immagine 2 di 2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 705
