Salta al contenuto principale
Sony UBP-UX80 Disc Drive Assembly Replacement
Cosa ti serve
  1. Sony UBP-UX80 Disc Drive Assembly Replacement, Top Cover: passo 1, immagine 1 di 3 Sony UBP-UX80 Disc Drive Assembly Replacement, Top Cover: passo 1, immagine 2 di 3 Sony UBP-UX80 Disc Drive Assembly Replacement, Top Cover: passo 1, immagine 3 di 3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
    • Slide both covers back about a 1/2 inch, then pull them away from the case.
  2. Sony UBP-UX80 Disc Drive Assembly Replacement: passo 2, immagine 1 di 3 Sony UBP-UX80 Disc Drive Assembly Replacement: passo 2, immagine 2 di 3 Sony UBP-UX80 Disc Drive Assembly Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws on the side of the case, each connecting to a tab on the cover.
    • Similar to the previous step, it is identical cases on both sides of the device.
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws (one next to the Wi-Fi logo and one next to the Blu-ray logo).
  3. Sony UBP-UX80 Disc Drive Assembly Replacement: passo 3, immagine 1 di 2 Sony UBP-UX80 Disc Drive Assembly Replacement: passo 3, immagine 2 di 2
    • Press in the tabs found on the front-sides of the case (connected to the front panel).
    • Slide the top cover forward.
    • Lift off the case.
  4. Sony UBP-UX80 Disc Drive Assembly Replacement: passo 4, immagine 1 di 3 Sony UBP-UX80 Disc Drive Assembly Replacement: passo 4, immagine 2 di 3 Sony UBP-UX80 Disc Drive Assembly Replacement: passo 4, immagine 3 di 3
    • Find the eleven 10.5 mm silver screws and two 6 mm black screws on the perimeter of the silver cover plate.
    • Remove the silver screws using a Phillips #2 screwdriver and the black ones using a Phillips #1 screwdriver.
    • Life the back of the cover up and off of the chasis.
  5. Sony UBP-UX80 Disc Drive Assembly Replacement, Disc Drive Assembly: passo 5, immagine 1 di 2 Sony UBP-UX80 Disc Drive Assembly Replacement, Disc Drive Assembly: passo 5, immagine 2 di 2
    • Find and remove the three ribbon connections leading to the motherboard.
    • Gently pull straight up. Be careful because ribbon cables are fragile.
  6. Sony UBP-UX80 Disc Drive Assembly Replacement: passo 6, immagine 1 di 2 Sony UBP-UX80 Disc Drive Assembly Replacement: passo 6, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the four 10.5 mm screws.
  7. Sony UBP-UX80 Disc Drive Assembly Replacement: passo 7, immagine 1 di 2 Sony UBP-UX80 Disc Drive Assembly Replacement: passo 7, immagine 2 di 2
    • Lift the back of the assembly slightly, and pull it back and out of the case to remove it.
Conclusione
Kenny Young
Membro da: 03/13/23
413 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 90
