Salta al contenuto principale
Sony Tablet S Factory / Hard reset
Panoramica Video
  1. Sony Tablet S Factory / Hard reset, Sony Tablet S Factory / Hard reset: passo 1, immagine 1 di 3 Sony Tablet S Factory / Hard reset, Sony Tablet S Factory / Hard reset: passo 1, immagine 2 di 3 Sony Tablet S Factory / Hard reset, Sony Tablet S Factory / Hard reset: passo 1, immagine 3 di 3
    • Metod 1:
    • - Settings
    • - Backup & reset
    • - Factory data reset
    • The tablet will restart automatically.
    • !!! From the "Backup & reset" menu you can do Back up my data !!!
  2. Sony Tablet S Factory / Hard reset: passo 2, immagine 1 di 3 Sony Tablet S Factory / Hard reset: passo 2, immagine 2 di 3 Sony Tablet S Factory / Hard reset: passo 2, immagine 3 di 3
    • Metod 2:
    • Power of the tablet. Pres and hold the Power On key and the Volume Up key at the same time.
    • When you see the Sony logo release the Power On button but continue to press the Volume Up button.
    • Now you are in the Android recovery menu. Use Volume keys to scroll and the Power On key to select. From the options select:
    • - Reset to Factory Settings
    • - Yes - erase all user data
    • - The tablet will restart alone
    • Please SUBSCRIBE to my channel ツ
Conclusione
Altre 19 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.203 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.521 Guide realizzate
23 Commenti
Hallo , I follow the steps , nothing is happening . Exists a different way ? dedudan@yahoo.com
Dedu Octavian - Replica
hi man
i do but its very VERY specific
press power
when te white led upper power flash on quiqkly relase power and press vol up..........
when the display make a very litle flash relase the vol buton
ENJOY AND GIVE THANKS
tunerlezoart4everx -
Hi, you are my knight in shining armour. You were right, it´s incredibly specific. You have to watch the white light above the power button and be plugged in into a socket. Nobody else mentioned the little white light, I was close to believe my tablet was defect.
Thank you very, very much.
Kat Hutnik -
than q
very use ful
kameswar - Replica
ive tried it many times but still is stuck on sony logo
fish luv72 - Replica
read my before coment
enjoy
I got to the Android selecting via the volume up/down page- but when I press the power button to select factory reset nothing happens.
kez - Replica
Thanks!!!! It worked. For guys who dont know, you should pług your tan to the electricity. Then everything works fine
mikolajpawlak04 - Replica
Yes. I had to try it about 10 times before it entered the "Rescue Mode". Don't opt for the rescue mode. You don't care about saving anything at this point. Press-"Skip". And it will go to full restore. Be patient. But the split second of both bottoms was hard.
drinkfromtenaja - Replica
Please see above comment.
It is similar to the hard reset of vaio laptops. That is, turning on and immediately pressing F-10 rapidly. It enters hard restore mode. But the tablet uses the pwr and + volume buttons together. Keep trying. My tablet works Fine now.
Make sure you're connected to power.
I know this is a long time ago, however just tried to start my xperia tablet as thought it was dead. Power and volume up button at same time ( charging led flashes twice) then I press power again and the white led lights up for about 1-2 seconds, I then press the up volume but no matter how long I hold the button down for there is nothing from the screen. Even if I keep pressing volume up button whilst pressing power again to get the white led, nothing happens.
Andrew Overington - Replica
This doesnt work
ngaval9901 - Replica
hello
it’s a working procedure, many thanks! Is there any way to update the android version to a more recent version above 4.0.3.?
Darde Sar - Replica
Hello!!!! Thanks for your help, excellente procedure, easy if you follow carefully the steps =)
Cristian Papic - Replica
no avanza de la parte del logo de sony y cuando intento hacer el hard reste con los botones hago lo mismo de presionar el encendido y el de vol+ ala ves y cuando sale el logo de sony lo suelto pero no entra al sistema y no avanza y nos que hacer ayuda
alberto - Replica
es una modelo sgpt122mx/s
alberto - Replica
I already made the factory reset, but it still does not change the sony logo that I can do
ya logre hacer el reseteo de fabrica pero sige sin pasar del logo de sony que puedo hacer
alberto - Replica
does anyone know how to hard reset spg611 z3 compact tab/pc CB5A22ELMC serial . none of the above have worked .Ive managed to get it into safe mode but that’s all. PLZZZZ HELP. i have forgotten the password , there was a reset password option but know there is not.
kevkayne - Replica
After I reset my sony tab it still will not boot up it won't go passed the sony please help
Della Hood - Replica
thank you ‘tunerlezoart4everx’ its specific and working :)
hi man
press power
tunerlezoart4everx - 11-09-2015
Test Hesabı - Replica
Man how many minutes it take to open after reset
Ahmed K - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 77
Tutti i Tempi: 86,397
