Salta al contenuto principale
Sony TCM-919 Cassette-Corder Operating Buttons Replacement
Cosa ti serve
  1. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Remove Back Cover: passo 1, immagine 1 di 1
    • Turn the device around so that the back cover if facing upward. Use your thumbs to press firmly down and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Back Cover Screw Removal: passo 2, immagine 1 di 1
    • Remove the 5 5.95mm screws as indicated in the picture with the Phillips Head screwdriver.
  3. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Locate Buttons: passo 3, immagine 1 di 1
    • Look to the back of the top cover and locate the broken button(s).
  4. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Detach Buttons: passo 4, immagine 1 di 2 Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Detach Buttons: passo 4, immagine 2 di 2
    • Use a splunger tool to undo the two clips that belong to any broken buttons.
    • Turn the device over and using your finger, push out the loose button.
Conclusione
Baylor, Team 4-3, Williams Fall 2014 Membro di Baylor, Team 4-3, Williams Fall 2014
BU-WILLIAMS-F14S4G3
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 816
