Salta al contenuto principale
Sony TCM-919 Cassette-Corder Motherboard Replacement
Cosa ti serve
  1. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Back Cover: passo 1, immagine 1 di 1
    • Turn the device around so that the back cover if facing upward. Use your thumbs to press firmly down and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Motherboard Replacement, Back Cover Screw Removal: passo 2, immagine 1 di 1
    • Remove the 5 5.95mm screws as indicated in the picture using the Phillips Head screwdriver.
  3. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove 3-Digit Tape Counter: passo 3, immagine 1 di 2 Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove 3-Digit Tape Counter: passo 3, immagine 2 di 2
    • Locate the 3-digit tape counter and gently push the tabs apart releasing the counter.
    • Pull the 3-digit tape counter out.
    • Remove the rubber band attaching the 3-digit tape counter to the cassette head.
  4. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Motor: passo 4, immagine 1 di 2 Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Motor: passo 4, immagine 2 di 2
    • Remove the screws as indicated in the picture using the Phillips Head screwdriver.
    • Pull the loosened motor out of the device, and set the motor aside.
  5. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove the Tape Deck: passo 5, immagine 1 di 3 Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove the Tape Deck: passo 5, immagine 2 di 3 Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove the Tape Deck: passo 5, immagine 3 di 3
    • Removes the 3, 5.95mm screws using the Phillips Head screwdriver as indicated by picture 1.
    • Push firmly on the tabs and lift the tape deck out.
    • Set the tape deck aside.
  6. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Motherboard Screws: passo 6, immagine 1 di 1
    • Remove the 2 5.95mm screws as indicated by the picture using the Phillips Head screwdriver.
  7. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Epoxy: passo 7, immagine 1 di 1
    • Remove the epoxy completely from the motherboard so that the wires underneath the epoxy can move freely.
  8. Sony TCM-919 Cassette-Corder Motherboard Replacement, Desolder Wires From Motherboard: passo 8, immagine 1 di 2 Sony TCM-919 Cassette-Corder Motherboard Replacement, Desolder Wires From Motherboard: passo 8, immagine 2 di 2
    • Remove the motherboard from case.
    • Flip the motherboard around so that the metallic green side is facing you.
    • Desolder the points indicated in picture 2. This should free the wires connected to the motherboard.
    • Remove the motherboard by pulling it out of the device cavity.
Conclusione
Baylor, Team 4-3, Williams Fall 2014 Membro di Baylor, Team 4-3, Williams Fall 2014
BU-WILLIAMS-F14S4G3
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,713
