Salta al contenuto principale
Sony TCM-919 Cassette-Corder Microphone Replacement
Cosa ti serve
  1. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove battery Cover: passo 1, immagine 1 di 1
    • Turn the device around so that the back cover if facing upward. Use your thumbs to press down firmly and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Back Casing: passo 2, immagine 1 di 1
    • Remove the 5, 5.95mm screws as indicated in the picture using the Phillips head screwdriver.
  3. Sony TCM-919 Cassette-Corder Microphone Replacement, Desolder Microphone Wires: passo 3, immagine 1 di 2 Sony TCM-919 Cassette-Corder Microphone Replacement, Desolder Microphone Wires: passo 3, immagine 2 di 2
    • Look to the back of the top cover.
    • Desolder the two wires connected to the mircophone using the soldering station.
  4. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Microphone: passo 4, immagine 1 di 2 Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Microphone: passo 4, immagine 2 di 2
    • Gently remove the rubber top from the two plastic knobs that hold the microphone in place.
    • Remove the microphone by pulling up.
Conclusione
Baylor, Team 4-3, Williams Fall 2014 Membro di Baylor, Team 4-3, Williams Fall 2014
BU-WILLIAMS-F14S4G3
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 503
