Salta al contenuto principale
Sony Smart Watch SW2 Motherboard Cover Replacement
Cosa ti serve
  1. Sony Smart Watch SW2 Motherboard Cover Replacement, Motherboard Cover: passo 1, immagine 1 di 2 Sony Smart Watch SW2 Motherboard Cover Replacement, Motherboard Cover: passo 1, immagine 2 di 2
    • Push down the smart watch housing with both thumbs while holding the outer frame.
    • Note that the power button will fall off of the frame. Set it aside in a safe place with the wristband.
  2. Sony Smart Watch SW2 Motherboard Cover Replacement: passo 2, immagine 1 di 2 Sony Smart Watch SW2 Motherboard Cover Replacement: passo 2, immagine 2 di 2
    • Detach the screen using the plastic prying tool.
    • Detach the LCD screen from the motherboard by pulling the ribbon cable very carefully and slowly.
  3. Sony Smart Watch SW2 Motherboard Cover Replacement: passo 3, immagine 1 di 2 Sony Smart Watch SW2 Motherboard Cover Replacement: passo 3, immagine 2 di 2
    • Using a the Spudger, remove the cover. Work your way around to find the most convenient place to open it.
Conclusione
IUPUI, Team S2-G2, Freund Spring 2018 Membro di IUPUI, Team S2-G2, Freund Spring 2018
IUPUI-FREUND-S18S2G2
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 773
