Salta al contenuto principale
Sony Smart Watch SW2 Display Assembly Replacement
Cosa ti serve
  1. Sony Smart Watch SW2 Display Assembly Replacement, Display Assembly: passo 1, immagine 1 di 1
    • Detach the smart watch from the band by pushing on the back of the watch housing.
    • The power button may fall out once the smart watch is detached.
    • Set aside the power button and watch band as they are no longer needed for further disassembly.
  2. Sony Smart Watch SW2 Display Assembly Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to carefully pry the LCD screen from the watch housing.
  3. Sony Smart Watch SW2 Display Assembly Replacement: passo 3, immagine 1 di 1
    • Use a plastic opening tool or spudger to lift the screen assembly press-fit connector free.
  4. Sony Smart Watch SW2 Display Assembly Replacement: passo 4, immagine 1 di 1
    • Set aside the detached LCD screen to access the battery.
Conclusione
To reassemble your device, follow these steps in reverse order.
Altre 3 persone hanno completato questa guida.
Vincent Shiue
Membro da: 01/22/18
265 Reputazione
2 Guide realizzate
IUPUI, Team S1-G5, Freund Spring 2018 Membro di IUPUI, Team S1-G5, Freund Spring 2018
IUPUI-FREUND-S18S1G5
3 Membri
2 Guide realizzate
1Commento della guida
whwre can I get the LCD screen for SW2?
faizal ahamed - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 15
Tutti i Tempi: 3,305
