Salta al contenuto principale
Sony SRS-XE200 Motherboard Replacement
Cosa ti serve
  1. Sony SRS-XE200 Motherboard Replacement, Speaker Assembly: passo 1, immagine 1 di 2 Sony SRS-XE200 Motherboard Replacement, Speaker Assembly: passo 1, immagine 2 di 2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Motherboard Replacement: passo 2, immagine 1 di 1
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Motherboard Replacement: passo 3, immagine 1 di 2 Sony SRS-XE200 Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Motherboard Replacement: passo 4, immagine 1 di 2 Sony SRS-XE200 Motherboard Replacement: passo 4, immagine 2 di 2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Motherboard Replacement, Motherboard: passo 5, immagine 1 di 3 Sony SRS-XE200 Motherboard Replacement, Motherboard: passo 5, immagine 2 di 3 Sony SRS-XE200 Motherboard Replacement, Motherboard: passo 5, immagine 3 di 3
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the cord connecting the charging port to the motherboard.
  7. Sony SRS-XE200 Motherboard Replacement: passo 7, immagine 1 di 3 Sony SRS-XE200 Motherboard Replacement: passo 7, immagine 2 di 3 Sony SRS-XE200 Motherboard Replacement: passo 7, immagine 3 di 3
    • Remove the two 0.8 mm screws attaching the motherboard to the case compartment with a Phillips #1 screwdriver.
    • Detach the motherboard from the case compartment.
Conclusione
Un commento
Hy please I m from morrocco i need a matherbeard a have a speaker but not work i d'not no way i need help plz
Abdou Abdou - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 49
Tutti i Tempi: 388
