Salta al contenuto principale
Sony SRS-XE200 Microphone Replacement
Cosa ti serve
  1. Sony SRS-XE200 Microphone Replacement, Speaker Assembly: passo 1, immagine 1 di 2 Sony SRS-XE200 Microphone Replacement, Speaker Assembly: passo 1, immagine 2 di 2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Microphone Replacement: passo 2, immagine 1 di 1
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Microphone Replacement: passo 3, immagine 1 di 2 Sony SRS-XE200 Microphone Replacement: passo 3, immagine 2 di 2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Microphone Replacement: passo 4, immagine 1 di 2 Sony SRS-XE200 Microphone Replacement: passo 4, immagine 2 di 2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Microphone Replacement, Battery: passo 5, immagine 1 di 3 Sony SRS-XE200 Microphone Replacement, Battery: passo 5, immagine 2 di 3 Sony SRS-XE200 Microphone Replacement, Battery: passo 5, immagine 3 di 3
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Microphone Replacement: passo 6, immagine 1 di 3 Sony SRS-XE200 Microphone Replacement: passo 6, immagine 2 di 3 Sony SRS-XE200 Microphone Replacement: passo 6, immagine 3 di 3
    • Remove the battery from the battery holder with a nylon spudger.
    • Unplug the battery from the motherboard.
  7. Sony SRS-XE200 Microphone Replacement, Charging Port: passo 7, immagine 1 di 2 Sony SRS-XE200 Microphone Replacement, Charging Port: passo 7, immagine 2 di 2
    • Remove the charging port.
  8. Sony SRS-XE200 Microphone Replacement, Microphone: passo 8, immagine 1 di 3 Sony SRS-XE200 Microphone Replacement, Microphone: passo 8, immagine 2 di 3 Sony SRS-XE200 Microphone Replacement, Microphone: passo 8, immagine 3 di 3
    • Remove the two 0.8 mm screws connecting the motherboard to the microphone with a Phillips #1 screwdriver.
    • Remove the microphone.
  9. Sony SRS-XE200 Microphone Replacement: passo 9, immagine 1 di 1
  10. Sony SRS-XE200 Microphone Replacement: passo 10, immagine 1 di 2 Sony SRS-XE200 Microphone Replacement: passo 10, immagine 2 di 2
  11. Sony SRS-XE200 Microphone Replacement: passo 11, immagine 1 di 3 Sony SRS-XE200 Microphone Replacement: passo 11, immagine 2 di 3 Sony SRS-XE200 Microphone Replacement: passo 11, immagine 3 di 3
    • Remove the microphone from the case of the speaker.
    • Replace the microphone.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 21
Tutti i Tempi: 216
