Salta al contenuto principale
Sony SRS-XE200 Battery Replacement
Cosa ti serve
  1. Sony SRS-XE200 Battery Replacement, Speaker Assembly: passo 1, immagine 1 di 2 Sony SRS-XE200 Battery Replacement, Speaker Assembly: passo 1, immagine 2 di 2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Battery Replacement: passo 2, immagine 1 di 1
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Battery Replacement: passo 3, immagine 1 di 2 Sony SRS-XE200 Battery Replacement: passo 3, immagine 2 di 2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Battery Replacement: passo 4, immagine 1 di 2 Sony SRS-XE200 Battery Replacement: passo 4, immagine 2 di 2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Battery Replacement, Battery: passo 5, immagine 1 di 3 Sony SRS-XE200 Battery Replacement, Battery: passo 5, immagine 2 di 3 Sony SRS-XE200 Battery Replacement, Battery: passo 5, immagine 3 di 3
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Battery Replacement: passo 6, immagine 1 di 3 Sony SRS-XE200 Battery Replacement: passo 6, immagine 2 di 3 Sony SRS-XE200 Battery Replacement: passo 6, immagine 3 di 3
    • Remove the battery from the battery holder with a nylon spudger.
    • Unplug the battery from the motherboard.
Conclusione
2 Commenti
Thanks what is the replacement battery number?
fred Pope - Replica
What is the battery number for the SRS replacement
fred Pope - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 55
Tutti i Tempi: 637
