Salta al contenuto principale
Sony SRS-XB30 Wires Replacement
Cosa ti serve
  1. Sony SRS-XB30 Wires Replacement, Battery: passo 1, immagine 1 di 1
    • To remove the speaker grill, insert the big spudger underneath it in each corner.
    • Work around the edges to pry the grill up and off.
  2. Sony SRS-XB30 Wires Replacement: passo 2, immagine 1 di 2 Sony SRS-XB30 Wires Replacement: passo 2, immagine 2 di 2
    • With the Sony logo facing towards you, use the medium spudger to lift the side plates from the internal frame.
    • This will need to be done on all four sides of the speaker to remove all four panels
    • This requires some effort because the adhesive is sticky.
  3. Sony SRS-XB30 Wires Replacement: passo 3, immagine 1 di 2 Sony SRS-XB30 Wires Replacement: passo 3, immagine 2 di 2
    • Locate the four screws on the now exposed front panel.
    • Using the screwdriver with bit T7, unscrew each screw (15.0 mm long).
  4. Sony SRS-XB30 Wires Replacement: passo 4, immagine 1 di 1
    • Next, remove the four outer edge screws, located on each corner of the speaker. The outer edge of the speaker is a clear plastic.
    • Use the same T7 screwdriver head here.
    • Remove each of the four corner screws (15.0 mm long).
  5. Sony SRS-XB30 Wires Replacement: passo 5, immagine 1 di 1
    • With a little force, carefully lift the lid of the speaker.
    • Make sure that you do not pull on the wires.
  6. Sony SRS-XB30 Wires Replacement: passo 6, immagine 1 di 3 Sony SRS-XB30 Wires Replacement: passo 6, immagine 2 di 3 Sony SRS-XB30 Wires Replacement: passo 6, immagine 3 di 3
    • Unclip the four wire connectors (that are attached to the speaker lid).
    • Disconnect the thin yellow wire (attached to the speaker lid) from its port.
  7. Sony SRS-XB30 Wires Replacement: passo 7, immagine 1 di 1
    • Separate the speaker lid from the bottom frame.
    • To prepare the speaker for the next step place the lid parallel to the frame.
  8. Sony SRS-XB30 Wires Replacement: passo 8, immagine 1 di 1
    • Locate the two silver screws (9 mm) attached to the two LED-light-chips on the speaker lid.
    • Using the screwdriver with bit PH1, unscrew each screw.
  9. Sony SRS-XB30 Wires Replacement: passo 9, immagine 1 di 1
    • Separate the speaker lid entirely from the bottom frame.
  10. Sony SRS-XB30 Wires Replacement: passo 10, immagine 1 di 1
    • Remove the top screw (10 mm).
    • Use the screwdriver with bit T7.
  11. Sony SRS-XB30 Wires Replacement: passo 11, immagine 1 di 2 Sony SRS-XB30 Wires Replacement: passo 11, immagine 2 di 2
    • Locate and remove the three black screws (10.0 mm) within the internal frame. Use bit T7.
    • There are two screws on the left side of the white box and one to its right.
  12. Sony SRS-XB30 Wires Replacement: passo 12, immagine 1 di 1
    • Slightly lift the white box with all the wires still attached.
  13. Sony SRS-XB30 Wires Replacement: passo 13, immagine 1 di 2 Sony SRS-XB30 Wires Replacement: passo 13, immagine 2 di 2
    • Take the big spudger and pry the black casing up from the circuit box.
  14. Sony SRS-XB30 Wires Replacement: passo 14, immagine 1 di 1
    • Locate the blue film attached to the circuit box containing the charging port.
    • Detach the blue film from the box.
  15. Sony SRS-XB30 Wires Replacement: passo 15, immagine 1 di 1
    • Detach the yellow, black and red wires by pulling them directly up.
  16. Sony SRS-XB30 Wires Replacement: passo 16, immagine 1 di 2 Sony SRS-XB30 Wires Replacement: passo 16, immagine 2 di 2
    • Insert the spudger along the battery edge and firmly hold the wires. Lift both sides up. The battery will pop out from its encasement.
  17. Sony SRS-XB30 Wires Replacement, Wires: passo 17, immagine 1 di 1
    • Locate the black, yellow, and red wires and steadily pull them smooth if they are tangled.
  18. Sony SRS-XB30 Wires Replacement: passo 18, immagine 1 di 1
    • Unravel any tangled wires or replace any damaged wires.
    • The wires should all run parallel to one another.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,445
