Salta al contenuto principale
Sony SRS-X55 Speaker Reverberator Replacement
Cosa ti serve
  1. Sony SRS-X55 Speaker Reverberator Replacement, Speaker Reverberator: passo 1, immagine 1 di 1
    • Locate the six 9 mm screws on the bottom of the speaker and remove them using Phillips head #2.
  2. Sony SRS-X55 Speaker Reverberator Replacement: passo 2, immagine 1 di 2 Sony SRS-X55 Speaker Reverberator Replacement: passo 2, immagine 2 di 2
    • Insert a plastic spudger into the seam on the bottom panel and lift it away from the rest of the speaker.
  3. Sony SRS-X55 Speaker Reverberator Replacement: passo 3, immagine 1 di 3 Sony SRS-X55 Speaker Reverberator Replacement: passo 3, immagine 2 di 3 Sony SRS-X55 Speaker Reverberator Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Locate the battery connection and unplug it using a pair of metal tweezers.
  4. Sony SRS-X55 Speaker Reverberator Replacement: passo 4, immagine 1 di 2 Sony SRS-X55 Speaker Reverberator Replacement: passo 4, immagine 2 di 2
    • Locate the remaining two 3.5 mm screws on the bottom of the I/O board and remove them using a Phillips head #2 screwdriver.
  5. Sony SRS-X55 Speaker Reverberator Replacement: passo 5, immagine 1 di 1
    • Remove the I/O board from the rest of the speaker. A plastic spudger can aid in this process if it is inserted into the edge as shown and gently pried.
  6. Sony SRS-X55 Speaker Reverberator Replacement: passo 6, immagine 1 di 2 Sony SRS-X55 Speaker Reverberator Replacement: passo 6, immagine 2 di 2
    • Insert a plastic spudger into the seam where the forward facing metal speaker cover meets the speaker body and gently pry it upward until it releases.
  7. Sony SRS-X55 Speaker Reverberator Replacement: passo 7, immagine 1 di 2 Sony SRS-X55 Speaker Reverberator Replacement: passo 7, immagine 2 di 2
    • Locate the eight 8.9 mm screws on the face of the speaker assembly and remove them using a Phillips head #2 screwdriver.
  8. Sony SRS-X55 Speaker Reverberator Replacement: passo 8, immagine 1 di 2 Sony SRS-X55 Speaker Reverberator Replacement: passo 8, immagine 2 di 2
    • Insert a plastic spudger underneath one of the tabs on the front of the speaker assembly and gently raise it.
    • Continue to the next step before attempting to lift the speaker assembly entirely away from the rest of the speaker to avoid damaging internal wire connections.
  9. Sony SRS-X55 Speaker Reverberator Replacement: passo 9, immagine 1 di 3 Sony SRS-X55 Speaker Reverberator Replacement: passo 9, immagine 2 di 3 Sony SRS-X55 Speaker Reverberator Replacement: passo 9, immagine 3 di 3
    • Locate the two wire connections as shown underneath of the speaker assembly and unplug them using a pair of tweezers.
    • Lift the speaker assembly away.
  10. Sony SRS-X55 Speaker Reverberator Replacement: passo 10, immagine 1 di 2 Sony SRS-X55 Speaker Reverberator Replacement: passo 10, immagine 2 di 2
    • Locate the eight 7.5 mm screws across both of the speaker reverberators and remove them using a Phillips head #2 screwdriver.
    • Lift the speaker reverberators away and replace them.
Conclusione
Altre 2 persone hanno completato questa guida.
Eric Coletto
Membro da: 01/26/17
113 Reputazione
1 Guida realizzata
IUPUI, Team 2-3, Baechle Spring 2017 Membro di IUPUI, Team 2-3, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G3
3 Membri
3 Guide realizzate
Un commento
Nice Guide, but do you know the exact speaker size and/or type?
I can not find the exact speakers.
THX
Elduderino79
El Duderino - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,508
