Salta al contenuto principale
Sony SRS-X55 I/O Board Replacement
Cosa ti serve
  1. Sony SRS-X55 I/O Board Replacement, Battery: passo 1, immagine 1 di 3 Sony SRS-X55 I/O Board Replacement, Battery: passo 1, immagine 2 di 3 Sony SRS-X55 I/O Board Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the six screw covers with a spudger.
    • Remove the six 11 mm Phillips screws from the bottom panel.
    • Remove the bottom panel of the speaker.
  2. Sony SRS-X55 I/O Board Replacement: passo 2, immagine 1 di 1
    • Disconnect the battery cable from the motherboard.
    • Remove the battery.
  3. Sony SRS-X55 I/O Board Replacement, I/O Board: passo 3, immagine 1 di 2 Sony SRS-X55 I/O Board Replacement, I/O Board: passo 3, immagine 2 di 2
    • Remove the two Phillips screws from the I/O board.
    • Remove the front panel to the speaker by pushing on the two tabs in the corners.
  4. Sony SRS-X55 I/O Board Replacement: passo 4, immagine 1 di 1
    • Disconnect the ribbon cable from the I/O board.
    • Carefully remove the I/O board from the speaker.
Conclusione
Un commento
Where can i get a new i/o board?
Kyle Workman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,350
