Introduzione
On this guide, the aim is to teach how to disassemble the Sony SRS-X3 bluetooth speaker in order to replace the speakers in the unit. This teardown is fairly simple, and only requires two tools. This speaker replacement is being completed because of a humming sound coming from the unit when music is being played.
Cosa ti serve
Pop off front speaker face (dark grey with little holes) by pushing out 3 tabs where screws were previously located and sticking spudger in crack where grey speaker face meets the outer shell
You may really have to pry on this part, it is not easy to remove and will pop out when released
Altre 3 persone hanno completato questa guida.
4 Commenti
Where would I get the new speakers from tho? Thanks a lot
Where I can buy one speaker as a spare part?
I would also like to know where I can get a replacement speaker
This SRS X3 cannot be used with the dc in 5v plugged, how can i do to make it work continuously with the charge cable? It have to be hacked? thanks
