Salta al contenuto principale
Sony SRS-X3 Battery Replacement
Cosa ti serve
  1. Sony SRS-X3 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the 6 philips head screws using the PH1 bit.
  2. Sony SRS-X3 Battery Replacement: passo 2, immagine 1 di 1
    • Remove the 3 philips head screws holding in the green circuit board
  3. Sony SRS-X3 Battery Replacement: passo 3, immagine 1 di 1
    • Unclip the battery pack and replace it with another one.
Conclusione
Altre 6 persone hanno completato questa guida.
3 Commenti
Can you give the battery # on this please
Dan Clark - Replica
Good instructions. I had one problem when removing the green circuit card. The ribbon cable came out. On mine there was a small black retention bar that I flipped open to allow the ribbon cable to reinsert, then I returned the retention bar back down to secure the ribbon cable in place. It worked fine after that.
Harpo - Replica
It would be nice if the article addressed the 6 rubber pads that cover the screws. There doesn't seem to be a way to remove them without damaging them, and you need them in order to use the speaker without it rattling and moving about from vibrations.
Peter Nosko - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 117
Tutti i Tempi: 6,985
