1. Phillips 00 Bit
    • Phillips 00 Bit
    • Plastic and metal spudgers
    • Plastic Pick
    • Tweesers
  2. Get one of your pry tools and pry up the back rubber.
    • Get one of your pry tools and pry up the back rubber.
    • Then peel back the rubber and put it to one side
    • The adhesive can be a bit hard at first but it should come loose. The adhesive will also stay on the rubber and can be re applied.
    • Get your 00 Phillips bit and unscrew all of the screws.
    • Then get a spudger and take off the back plastic pannel
    • Get a plastic spudger and carefully pry the battery out.
    • Give the power connector a firm tug whilst wiggling the connector back and forth.
    • Alternatively you could use your tweezers to pry the connector out.
    • DO NOT use a metal pry tool for this process because you don't want to puncture the battery.
    • Use a pry tool to remove the top cover like you did in Step 2
    • Then peel back the rubber and put it to one side.
    • Just like the back cover the adhesive can be hard at first. It can also be reapplied when you reassemble.
    • Get you screwdriver and unscrew the screws.
    • Once all of the screws are removed you can then pull out the board.
    • You can remove the ribbon cable with your fingers or with some tweezers.
    • The screws for the top panel are different so you'll want to keep them separate.
    • Get a metal pry tool and get it between the rubber and the plastic.
    • Once you have a good piece preyed up you can remove it with your hand.
    • This will deform the plastic a little bit but you can re-adhere this to the plastic underneath.
    • Get your screwdriver and unscrew all of the screws.
    • You can the get a pry tool and pry up the plastic panel.
    • If the panel doesn't come off completely try unscrewing the screws a little more until the plastic panel comes off with the rubber.
    • Get your tweezers and pry off the connector being careful not to tear the cable.
    • You can then get a plastic pry tool and put it in one of the corners of the board to pry it up and out of the casing.
    • You can then remove the speaker cable and the top board cable.
Conclusione
Altre 2 persone hanno completato questa guida.
Hadena
Membro da: 13/07/2018
476 Reputazione
2 Guide realizzate
Dear sir,
Can you supply boards for sony SRS-X11 boards kindly replay immediately.
kamath
biomedical engineer
nagkamath@gmail.com
kamath - Replica
our device is not getting on, no indication can you any thing to check.
kamath - Replica
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 60
Tutti i Tempi: 273
