Salta al contenuto principale
Strumenti
Nessun attrezzo specificato.
Ricambi
  1. Unscrew the screws on the top of the radio.
    • Unscrew the screws on the top of the radio.
  2. Open the CD and cassette doors and remove the screws in the compartments. To open the CD door push on the bottom left corner of the CD door. To open the cassette door push the button that is to the left of the pause button.
    • Open the CD and cassette doors and remove the screws in the compartments.
    • To open the CD door push on the bottom left corner of the CD door. To open the cassette door push the button that is to the left of the pause button.
  3. Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
    • Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
  4. Remove the top of the radio enough to access the wires for removal.
    • Remove the top of the radio enough to access the wires for removal.
    • Do not forcefully remove the whole top piece of the radio! There will be wires connected to the top cover and circuit board.
  5. Remove all of the wires that are connected to both the circuit board and the underside of  the top of the radio by pulling them where they are connected
    • Remove all of the wires that are connected to both the circuit board and the underside of the top of the radio by pulling them where they are connected
    • This should include three sets of red and white wires, one set of white wires, one set of black wires, and two ribbon wires. Some cannot be disconnected from the top piece of the radio. Disconnect these plugs from the circuit board.
  6. Unscrew the screws in the circuit board.
    • Unscrew the screws in the circuit board.
  7. Unlodge the green headphone jack on the back of the circuit board by pulling on the back of the radio and lifting the circuit board up.
    • Unlodge the green headphone jack on the back of the circuit board by pulling on the back of the radio and lifting the circuit board up.
    • This may be a little difficult and don't pull to hard because the radio may crack.
  8. Lift the circuit board out of the radio.
    • Lift the circuit board out of the radio.
  9. Insert and align the new circuit board and screw it down.
    • Insert and align the new circuit board and screw it down.
  10. Reconnect the wires that were unplugged from the prerequisite steps.
    • Reconnect the wires that were unplugged from the prerequisite steps.
Conclusione
Altre 4 persone hanno completato questa guida.
Ian Nussman
Membro da: 25/10/2013
881 Reputazione
6 Guide realizzate
Where can I get the part?
Francois - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 31
Tutti i Tempi: 4,435
