Salta al contenuto principale
Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement
Cosa ti serve
  1. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement, Sony Radio Model CFD S05 Prerequisite steps Replacement: passo 1, immagine 1 di 1
    • Unscrew the screws on the top of the radio.
  2. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: passo 2, immagine 1 di 2 Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: passo 2, immagine 2 di 2
    • Open the CD and cassette doors and remove the screws in the compartments.
    • To open the CD door push on the bottom left corner of the CD door. To open the cassette door push the button that is to the left of the pause button.
  3. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: passo 3, immagine 1 di 1
    • Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
  4. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: passo 4, immagine 1 di 1
    • Remove the top of the radio enough to access the wires for removal.
    • Do not forcefully remove the whole top piece of the radio! There will be wires connected to the top cover and circuit board.
  5. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: passo 5, immagine 1 di 1
    • Remove all of the wires that are connected to both the circuit board and the underside of the top of the radio by pulling them where they are connected
    • This should include three sets of red and white wires, one set of white wires, one set of black wires, and two ribbon wires. Some cannot be disconnected from the top piece of the radio. Disconnect these plugs from the circuit board.
  6. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement, Circuit Board: passo 6, immagine 1 di 1
    • Unscrew the screws in the circuit board.
  7. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: passo 7, immagine 1 di 1
    • Unlodge the green headphone jack on the back of the circuit board by pulling on the back of the radio and lifting the circuit board up.
    • This may be a little difficult and don't pull to hard because the radio may crack.
  8. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: passo 8, immagine 1 di 1
    • Lift the circuit board out of the radio.
  9. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: passo 9, immagine 1 di 1
    • Insert and align the new circuit board and screw it down.
  10. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: passo 10, immagine 1 di 1
    • Reconnect the wires that were unplugged from the prerequisite steps.
Conclusione
Altre 5 persone hanno completato questa guida.
Ian Nussman
Membro da: 10/25/13
959 Reputazione
6 Guide realizzate
1Commento della guida
Where can I get the part?
Francois - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 35
Tutti i Tempi: 6,367
