Salta al contenuto principale
Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement
Cosa ti serve
  1. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement, Sony Radio Model CFD S05 Prerequisite steps Replacement: passo 1, immagine 1 di 1
    • Unscrew the screws on the top of the radio.
  2. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: passo 2, immagine 1 di 2 Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: passo 2, immagine 2 di 2
    • Open the CD and cassette doors and remove the screws in the compartments.
    • To open the CD door push on the bottom left corner of the CD door. To open the cassette door push the button that is to the left of the pause button.
  3. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: passo 3, immagine 1 di 1
    • Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
  4. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: passo 4, immagine 1 di 1
    • Remove the top of the radio enough to access the wires for removal.
    • Do not forcefully remove the whole top piece of the radio! There will be wires connected to the top cover and circuit board.
  5. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: passo 5, immagine 1 di 1
    • Remove all of the wires that are connected to both the circuit board and the underside of the top of the radio by pulling them where they are connected
    • This should include three sets of red and white wires, one set of white wires, one set of black wires, and two ribbon wires. Some cannot be disconnected from the top piece of the radio. Disconnect these plugs from the circuit board.
  6. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement, Belt for the Tape Motor: passo 6, immagine 1 di 1
    • Locate the motor of the radio on the underside of the top of the radio.
  7. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: passo 7, immagine 1 di 1
    • Unscrew the screw holding the motor to the top of the radio.
  8. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: passo 8, immagine 1 di 1
    • Lift up the motor.
    • Don't lift too high because the motor stand will break.
  9. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: passo 9, immagine 1 di 1
    • Unhook the larger band from under the motor and remove it.
  10. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: passo 10, immagine 1 di 1
    • Replace the band by hooking it beneath the motor.
  11. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: passo 11, immagine 1 di 1
    • Push the motor back down and screw it into place.
    Nice... Worked for me and concise...... Now to find a belt. Thanks
    Tom - Replica
Conclusione
Altre 3 persone hanno completato questa guida.
Ian Nussman
Membro da: 10/25/13
959 Reputazione
6 Guide realizzate
Un commento
I'm worried about removing wires. How do you put them back? Doesn't that take some kind of special equipment/glue?
Carolyn Farley - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 31
Tutti i Tempi: 4,980
