Introduzione
This guide demonstrates how to open up your headset and locate the speaker for replacement if it stops working.
Cosa ti serve
Locate the left side designation on the headband-earpiece junction.
The battery is in the right earpiece.
The motherboard is in the left earpiece.
Gently pull around the perimeter of the left ear cushion until it comes off.
Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
Gently pull the outer ear rim off of the headset assembly.
Using tweezers, gently pry the red and black speaker wires from the attached socket.
Locate the junction of the electrical speaker and the plastic speaker housing.
Use the spudger to sever the glue at this junction.
Remove the electrical speaker from the speaker housing.
Altre 4 persone hanno completato questa guida.
