Salta al contenuto principale
Sony Pulse Elite Edition Speaker Replacement
Cosa ti serve
  1. Sony Pulse Elite Edition Speaker Replacement, Identifying Earpiece: passo 1, immagine 1 di 1
    • Locate the left side designation on the headband-earpiece junction.
    • The battery is in the right earpiece.
    • The motherboard is in the left earpiece.
  2. Sony Pulse Elite Edition Speaker Replacement, Ear Cushion Removal: passo 2, immagine 1 di 2 Sony Pulse Elite Edition Speaker Replacement, Ear Cushion Removal: passo 2, immagine 2 di 2
    • Gently pull around the perimeter of the left ear cushion until it comes off.
  3. Sony Pulse Elite Edition Speaker Replacement, Outer Ear Rim Removal: passo 3, immagine 1 di 2 Sony Pulse Elite Edition Speaker Replacement, Outer Ear Rim Removal: passo 3, immagine 2 di 2
    • Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
    • Gently pull the outer ear rim off of the headset assembly.
    • Harsh removal may cause permanent damage to the speaker wires.
  4. Sony Pulse Elite Edition Speaker Replacement, Remove Speaker Housing: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, gently pry the red and black speaker wires from the attached socket.
  5. Sony Pulse Elite Edition Speaker Replacement, Speaker: passo 5, immagine 1 di 2 Sony Pulse Elite Edition Speaker Replacement, Speaker: passo 5, immagine 2 di 2
    • Locate the junction of the electrical speaker and the plastic speaker housing.
    • Use the spudger to sever the glue at this junction.
    • Remove the electrical speaker from the speaker housing.
  6. Sony Pulse Elite Edition Speaker Replacement: passo 6, immagine 1 di 1
    • Use super glue to fasten the replacement speaker into the speaker housing.
Conclusione
Altre 4 persone hanno completato questa guida.
Armon Davani
Membro da: 01/29/15
400 Reputazione
2 Guide realizzate
Clemson, Team 14-2, Shirley Spring 2015 Membro di Clemson, Team 14-2, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G2
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 31
Tutti i Tempi: 2,914
