Salta al contenuto principale
Sony Pulse Elite Edition Headband Replacement
Cosa ti serve
  1. Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: passo 1, immagine 1 di 2 Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: passo 1, immagine 2 di 2
    • Remove the two 5mm Phillips #00 screws from each side of the headband connected to the metal track.
  2. Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: passo 2, immagine 1 di 2 Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: passo 2, immagine 2 di 2
    • After removing the screws, push the small plastic protector on one of the sides towards the speaker closest to it.
    • After the protector has slid out of its slot, pull it away from the bar until it pops off the track.
    • Repeat this process for small plastic protector on the other side.
  3. Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: passo 3, immagine 1 di 3 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: passo 3, immagine 2 di 3 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: passo 3, immagine 3 di 3
    • Using your thumb, slide the cushion on one of the two adjusting rails toward the closest speaker.
    • Once enough of the cushion has separated from the rail, pull the rest of it off.
    • Repeat the process for the other rail.
  4. Sony Pulse Elite Edition Headband Replacement, Slide Headband Off Rails: passo 4, immagine 1 di 1
    • Gently pull the headband away from one of the speaker component groups, as if expanding it. Continue pulling until it is completely off the track.
    • Remove the white and red wires from inside the headband.
    • Be sure to keep the two speakers close together since they are still linked via the speaker wires.
    • Repeat this process for the other side.
Conclusione
Altre 3 persone hanno completato questa guida.
Clemson, Team 14-2, Shirley Spring 2015 Membro di Clemson, Team 14-2, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G2
5 Membri
12 Guide realizzate
Un commento
have any experience with the sony gold headset, i got two of them that broke in the same spot, right at the hinge
Rich Gallagher - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 87
Tutti i Tempi: 5,836
