Salta al contenuto principale
Sony PlayStation Camera Motherboard Replacement
Cosa ti serve
  1. Sony PlayStation Camera Motherboard Replacement, Motherboard/Camera(s): passo 1, immagine 1 di 2 Sony PlayStation Camera Motherboard Replacement, Motherboard/Camera(s): passo 1, immagine 2 di 2
    • Separate the camera from the camera stand to gain access to the bottom of the camera.
  2. Sony PlayStation Camera Motherboard Replacement: passo 2, immagine 1 di 2 Sony PlayStation Camera Motherboard Replacement: passo 2, immagine 2 di 2
    • Using a PH000 sized screwdriver, remove the two 6.5mm Phillips #000 screws located under the stand connection point, where the cable enters the case.
  3. Sony PlayStation Camera Motherboard Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, remove the cap holding the cable grommet in place.
  4. Sony PlayStation Camera Motherboard Replacement: passo 4, immagine 1 di 1
    • Using the tweezers, remove both poly-carbonate lens coverplates.
    • Lift the coverplates slowly, to ensure they do not crack, or break.
  5. Sony PlayStation Camera Motherboard Replacement: passo 5, immagine 1 di 2 Sony PlayStation Camera Motherboard Replacement: passo 5, immagine 2 di 2
    • Using the PH0 sized screwdriver, remove two 3.2mm Phillips #0 screws, located under the coverplates.
  6. Sony PlayStation Camera Motherboard Replacement: passo 6, immagine 1 di 1
    • Using extreme care, separate the front of the case, from the back with a metal spudger, or pry tool. The case will scratch easily.
    • The case joints can be hard to spot. They appear as a very fine line in the plastic. Start with light pressure until the seam parts, allowing the pry tool to work.
  7. Sony PlayStation Camera Motherboard Replacement: passo 7, immagine 1 di 2 Sony PlayStation Camera Motherboard Replacement: passo 7, immagine 2 di 2
    • Using the PH0 sized screwdriver, remove the four 4.5mm Phillips #0 screws securing the circuit assembly to the device housing.
  8. Sony PlayStation Camera Motherboard Replacement: passo 8, immagine 1 di 3 Sony PlayStation Camera Motherboard Replacement: passo 8, immagine 2 di 3 Sony PlayStation Camera Motherboard Replacement: passo 8, immagine 3 di 3
    • Lift the motherboard and frame from the plastic housing.
    • Disconnect the camera cable from the motherboard.
  9. Sony PlayStation Camera Motherboard Replacement: passo 9, immagine 1 di 2 Sony PlayStation Camera Motherboard Replacement: passo 9, immagine 2 di 2
    • Using the PH0 sized screwdriver, remove the six 4.2mm Phillips #0 screws securing the motherboard to the metal frame.
  10. Sony PlayStation Camera Motherboard Replacement: passo 10, immagine 1 di 3 Sony PlayStation Camera Motherboard Replacement: passo 10, immagine 2 di 3 Sony PlayStation Camera Motherboard Replacement: passo 10, immagine 3 di 3
    • Using a plastic opening tool, disconnect the microphone array connector from the motherboard.
Conclusione
Joshua Gates
Membro da: 02/15/17
268 Reputazione
2 Guide realizzate
USF Tampa, Team 5-5, Passmore Spring 2017 Membro di USF Tampa, Team 5-5, Passmore Spring 2017
USFT-PASSMORE-S17S5G5
3 Membri
4 Guide realizzate
Un commento
I'm guessing you didn't pin out the cable?
So far I get the following pinout, with one pin with no continuity to I'm assuming my issue is there.
Place both cables so the rounded corners are at the top. The two longer pins on the internal cable will be on the right as you look at it. The PS4 accessory cable end should have the plastic tab carrying the pins at the top as you look at it.
PS4 accessory connector -> Camera internal cable
1 - 7
2 - 1
3 - 2
4 - 3
5 - 4
6 - 5? - broken in my cable or no connection by default
7 - 6
Hope that helps someone.
infiniti25 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,539
