Salta al contenuto principale
Sony PlayStation 3D Display Rear Case Replacement
Cosa ti serve
  1. Sony PlayStation 3D Display Rear Case Replacement, Rear Case: passo 1, immagine 1 di 2 Sony PlayStation 3D Display Rear Case Replacement, Rear Case: passo 1, immagine 2 di 2
    • Remove the base by pushing in the button and sliding out the unit.
    Como se consigue la base de unidad sola??
    no encuentro en ninguna parte, de casualidad tu sabras?
    DYLAN DGUEZ - Replica
  2. Sony PlayStation 3D Display Rear Case Replacement: passo 2, immagine 1 di 3 Sony PlayStation 3D Display Rear Case Replacement: passo 2, immagine 2 di 3 Sony PlayStation 3D Display Rear Case Replacement: passo 2, immagine 3 di 3
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display Rear Case Replacement: passo 3, immagine 1 di 2 Sony PlayStation 3D Display Rear Case Replacement: passo 3, immagine 2 di 2
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display Rear Case Replacement: passo 4, immagine 1 di 3 Sony PlayStation 3D Display Rear Case Replacement: passo 4, immagine 2 di 3 Sony PlayStation 3D Display Rear Case Replacement: passo 4, immagine 3 di 3
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 12-16, Maness Fall 2015 Membro di Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
4 Membri
8 Guide realizzate
Un commento
I got a used display that for some reason came with no screws on the back panel. Can you tell me exactly what type those 6x6mm and 6x8mm screws are? Especially wary since you said the thread sizes are different
Kodi Taylor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,591
