Cosa ti serve
If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
Pull the card out with your fingers.
First, turn the camera upside down.
Press the button located next to silver lens mount and rotate the lens counterclockwise.
Pull the lens away from the camera body.
Start by removing the two 5/32" #00 screws on the bottom of the camera using the Phillips #00 screwdriver.
Starting at the bottom, gently pry the back panel away from the body of the camera using your fingers.
Once the back panel is free from the body, rotate the camera such that back is facing you and pull the back panel past the screen by rotating it to fit around the screen.
Set the back panel aside.
