Salta al contenuto principale
Sony NEX-5T SD Card Replacement
Cosa ti serve
  1. Sony NEX-5T SD Card Replacement, SD Card: passo 1, immagine 1 di 3 Sony NEX-5T SD Card Replacement, SD Card: passo 1, immagine 2 di 3 Sony NEX-5T SD Card Replacement, SD Card: passo 1, immagine 3 di 3
    • Make sure to turn the cameras power switch to off before beginning this step.
    • Begin by holding the camera upside down with the bottom facing you. Identify the housing for the SD card, and battery.
    • You will use your other hand to slide the lock switch to this housing to the right. This will release the cap, allow it to come upwards.
  2. Sony NEX-5T SD Card Replacement: passo 2, immagine 1 di 3 Sony NEX-5T SD Card Replacement: passo 2, immagine 2 di 3 Sony NEX-5T SD Card Replacement: passo 2, immagine 3 di 3
    • Now that the cap to the battery and SD card housing is open, the SD card is visible.
    • You will need to press down on the SD card until you hear a click. Release the SD card and it will now be available to remove.
    • Grip the SD card and pull it out of the SD card slot.
  3. Sony NEX-5T SD Card Replacement: passo 3, immagine 1 di 3 Sony NEX-5T SD Card Replacement: passo 3, immagine 2 di 3 Sony NEX-5T SD Card Replacement: passo 3, immagine 3 di 3
    • To reinsert the SD card place it in its housing.
    • You will then need to push down on the SD card until you hear a click.
    • To ensure the SD card is in place you can visually inspect it. The SD card should be flush with the housing.
  4. Sony NEX-5T SD Card Replacement: passo 4, immagine 1 di 3 Sony NEX-5T SD Card Replacement: passo 4, immagine 2 di 3 Sony NEX-5T SD Card Replacement: passo 4, immagine 3 di 3
    • You may now close the housing for the SD card and battery.
    • Close the cap and while holding it down slide the locking tab to the left. This step should lock the cap in place.
    • Your SD card is now safely in place and you may turn your device on.
Linea Traguardo
USF Tampa, Team S13-G2, Cagle Spring 2017 Membro di USF Tampa, Team S13-G2, Cagle Spring 2017
USFT-CAGLE-S17S13G2
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 23
Tutti i Tempi: 866
